# 200% CPU, broken filter in a document and interactive elements (e.g. checkboxes) not responding
**URL:** <https://connect.superhuman.com/t/200-cpu-broken-filter-in-a-document-and-interactive-elements-e-g-checkboxes-not-responding/8669>\
**Created:** [June 19, 2019, 7:28pm UTC](https://connect.superhuman.com/t/200-cpu-broken-filter-in-a-document-and-interactive-elements-e-g-checkboxes-not-responding/8669 "2019-06-19T19:28:41Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![anon75668007](https://avatars.discourse-cdn.com/v4/letter/a/e47c2d/32.png) [@anon75668007](https://connect.superhuman.com/u/anon75668007)\
**Post date:** [June 19, 2019, 7:28pm UTC](https://connect.superhuman.com/t/200-cpu-broken-filter-in-a-document-and-interactive-elements-e-g-checkboxes-not-responding/8669/1 "2019-06-19T19:28:41Z")
</div>
My coda document is basically broken. I was editing a filter and now (1) anything I do on the filter does not change what is actually being filtered and (2) I get 200% CPU whenever I reload the document - I got used to reloading the document to fix glitches I would have.
No complaints, Coda’s pretty useful and I’m not paying a dime. However, to my biggest surprise, I could not find any support contact. How can I get in touch with the Coda developers ?
**Author:** ![Jean\_Pierre\_Traets](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/jean_pierre_traets/32/16275_2.png) [@Jean\_Pierre\_Traets](https://connect.superhuman.com/u/Jean_Pierre_Traets)\
**Post date:** [June 19, 2019, 7:33pm UTC](https://connect.superhuman.com/t/200-cpu-broken-filter-in-a-document-and-interactive-elements-e-g-checkboxes-not-responding/8669/2 "2019-06-19T19:33:15Z")
</div>
Welcome to the community @anon75668007
At [support@coda.io](mailto:support@coda.io) you will get the support you need.
**Author:** ![Paul\_Danyliuk](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/paul_danyliuk/32/27228_2.png) [@Paul\_Danyliuk](https://connect.superhuman.com/u/Paul_Danyliuk)\
**Post date:** [June 19, 2019, 7:37pm UTC](https://connect.superhuman.com/t/200-cpu-broken-filter-in-a-document-and-interactive-elements-e-g-checkboxes-not-responding/8669/3 "2019-06-19T19:37:46Z")
</div>
The (?) button in the bottom right — opens a support chat.
 ![image](https://global.discourse-cdn.com/coda1/original/2X/b/b2e3417f1e9cce0e739ed5a28ec33bbad3db01f8.png)
Easily overlooked, I know.
P.S. Try to roll back your document to a previous version. Saved me a few times when I screwed up my formulas:
 ![image](https://global.discourse-cdn.com/coda1/original/2X/2/23986f5930aae9a55d4a82bc2013e394a1cc93ab.png)
