Hello community! Today I come with a challenge that I don’t know if it can be solved with Coda. I have a document with two pages, the first one is “records” where there is a table showing 2 columns:
- Record Name
- Category
And a second page called “logs” where there is another table with 3 columns:
- Record Name
- Category
- Grades
The first two columns are brought from the table found in “records”. The last one is a canvas that contains another table inside as shown in the image
What I am trying to achieve is that when creating a new row in the logs table and it has the same Record Name, it automatically brings the value of the record from the last row that has the same name. Something like the following image
Here is the file in case you want to take a deeper look Records · Example
I have tried to find the solution using conditionals, connections between tables but honestly I have not been able to achieve it yet. Somebody could help me?
Thanks in advance
