Add or Modify Rows - Filter
Hey, I believe this should be an easy thing to do, and I swear I’ve done it in one of my other docs but I just seem to be stumped here. When I click the button on a row in Media Files to sync to the Content Calendar - it continually creates a new row and doesn’t match. Appreciate any support here - the community has always been an amazing resource for such an amazing platform.
Thanks,
Pat
Hello @Patrick_McDonald!
The problem there is that you are comparing a row to a text. You have to be careful with the icons in the formulas
image <- this icon means it is a row
image <- this means it is text
Try comparing File Name = thisRow to see if this resolves your issue.
