I’ve looked at all the add or modify rows and I still don’t understand.
I want to basically duplicate-ish an existing table with less columns and separate from the other one.
I need to keep existing data, in the table so I can first delete and clear the table.
So I’m trying to use the AddorModifyRows()
I want to check the OG table to the New table, for each row, If there is a match modify that row, and if no match then add row. Seems simple enough, but it keeps adding rows rather than modifying.
Obviously an expression issue, but I can’t seem to find a way to check the whole OG table, find the current value of New table, then validate if there’s a change and modify or ignore.
and if there’s a row in OG table not present in new table then add it to new table.
I’ve tried so many things I lost track, any fresh perspective?
Thanks !
