Will it be possible to add the functionality to rotate text such as Google Sheets allows? For example, when I need a simple check box, it is useful to add a title vertical to save empty space. Thanks!
To extend this idea, additional option to rotate (individual) column-headers…
just running into this now. Im creating an employee training tracker which will be a lot of checkboxes. if labels could be vertical it would save a ton of real estate. Currently i have to stick with Google Sheets for this because the visualization in Coda is just going to be unsuable
Doing exactly the same thing as Irfan. We are stuck to Sheets too. 45 degrees on headings would really help here.
Any feedback from the devs?
We’d need this feature as well, especially in grouped sections in lists
It would be good to have this for both column names and for groups (if I have a matrix with checkboxes, it is created by using groups).
