API generating 500 error returing a control value with no reason
Yesterday night API exposed controlls started returning a not so straightforward error message as follows:
“statusCode”: 500,
“statusMessage”: “Internal Server Error”,
“message”: “Canvas control value is not a control value: “””
This is a multiselector with a table filtered as options and was working just right yesterday up to 10:30PM EST
Has been any kind of API update that might be generating this? Is a blocking error for a perfectly working app.
Thanks for flagging. This is a bug on our end. Working on a fix now. Sorry for the inconvenience!
Hi Kelsey, can we get any update on this? It’s keeping a few of our documents from properly working. Some of them are used daily?
Thank You
The bug fix is in and should make it out today. Sorry again for the inconvenience!
The bug fix should be live now :ok_hand:
Seems to work fine Kelsey, thank you a lot!
