I’d like to remove all items that are present in one array from another array in a formula. Ex:
Array1 [Blue, Orange, Green, Yellow]
Array2 [Blue, Orange]
Array1 - Array2 = [Green, Yellow]
Is this possible?
Is this possible?
Here’s one way you can do it!
Depending on your specific use-case there may be better ways but this should give you a good enough starting point
Took me a bit of head scratching but I think this should work for you if you want to keep it all within a formula:
Array1.Filter(CurrentValue.In(Array2).Not())
=Look at each item in Array1. If it’s not in array 2, let it pass through the filter and be kept in our output array
Edit: Scott’s image wasn’t showing for me initially, didn’t realize this is exactly the same solution ![]()
Thanks Scott! Works great!
