I am looking to achieve deflate + base64 as per Kroki documentation for GET http queries.
The existing EncodeAsBase64() formula is missing options to perform deflate/compression. Is there any way to achieve this within Coda ?
Thanks
Thanks
Hi @Laurent_Ades,
If this is for pack building in Coda I would encourage you to look at our pack building documentation that gives an overview of what you can achieve in with Coda Packs. Here is an example of that documentation. Hope that helps!
