BETA Coda Form embed won't submit without login
The new coda form won’t submit without a login when embedded as an iframe on a Wordpress page. The form setting REQUIRE LOGIN is set to ‘Off’. It works fine as an external share link, just not when embedded.
It should be noted I tried the sign in link using my Google account and it returned accounts.google.com refused to connect.
The engineering team is gathering feedback through this doc if you’d like to add this or anything else that you notice…
Thank you for seeing this and reporting!
Thanks Ben, I have submitted feedback
