Blue dot autofill option
Is there a quick way to get the drag-down blue dot for autofill when done editing a field, without having to tab, enter, or click in another field and then go back to the field you were editing to get the blue dot to appear?
You can press ESC on your keyboard and the blue dot will appear on the field you were just editing!
Thank you!! That worked. That is one key I had not tried yet.
