Build Ai Agents in Coda - Training - Beta Test Cohort
Just watched the second workshop and just took the resolution to make sure I do not watch the others on a Friday. This is waaaay too much brain stimulation right before the weekend.
I felt already really empowered after the first workshop but that brings it to a whole other level!
Thank you, @Max_OBrien for putting these together and sharing. Top notch content, greatly structured, and neatly presented. Can’t wait to get to the next ones.
Cheers.
Hey @Max_OBrien , hey Max,
Unfortunately I had to watch the recordings, I had much more preferred to attended the live session. That said, watching the recordings allows me to take a breather every once in a while to make sure the contend is really landing….
All if this is very inspiring and extremely enlightening. It is complicated and I realize even more than I already did what a head start you you have on most of us. It’s encouraging that the the actual techniques seem not to be overly complicated when using your trainings as guidance. At the same time, it’s not overly simple either. I am left with the impression that a maker has to be really methodical when setting up the framework for using this in your daily operation.
You mentioned templates: I hope you will make some of what we have seen in the recordings available for us to study and use as a base for our own projects. I will have to watch all three recordings again to get more acquainted with this advanced use of AI, but I hope one of the templats will contain the table (or part of it) where you incorporate the knowledge base (like the Coda API or the CFL) and convert it to usable markup and YAML - even if it is only a couple of rows it will give us better insight in what is going on.
I realize how much time got into figuring all this out - it must have been a painstaking process to get it to work. Some of us would never be able to reproduce this from scratch, but a sample doc or template will go a long way.
Thank you for sharing so much of your expertise with us.
Greetings,
Joost
Hey Max,
I just recently caught up on your workshops, what a gold mine! I like that you give some quick tips that even total beginners can use to level up their AI game but there’s so much depth to explore forthose who want to go deeper. The amount of value per minute is incredible and you give it away for free! The Coda Community is really lucky to have you :raising_hands:
Thank you for holding our hands as we descend into the agentic rabbit-hole :lobster:
Pablo
