Can I get comments to sync with Cross-doc?
I create a report center for CEO and I thought it was perfect, but didn’t anticipate how leaving a comment for his managers would then allow them to enter the doc and see other managers reports. So I thought I found the solution with Cross-Doc however, now that I’m creating individual docs for each department and syncing tables for the CEO’s report center…I realize the CEO’s comments aren’t transferring over which defeats the purpose of using cross-doc.
Is there a way to bring comments over or is my entire construction wrong?
As far as I know its not possible to carry comments over, or target them in formulas in anyway…
It would definitely be very cool feature for Coda to implement.
