Can I use Coda for....?
Hi Guys.
Love the idea of Code. I currently sell a tennis journal for tennis players to record their match data.
I would like to put together an online version of the journal myself without the aid of any developer where a player can:
  • Log In
  • Add/Update/Delete Matches
  • See basic stats based on above
Can this be done with coda?
Thanks
Fabio
You definitely can use Coda for this. From a first glance, I would say that all features listed are possible. There are also nice sharing features so you could create a document as a template and people can copy that document and make it their own.
I think the only question is charging for it’s use. Once someone has the document, they can share it with anyone else.
Hey Ben thanks for the reply. The more I look into it the more I think it won’t work.
Ideally you would 1 doc for each player?. The player would sign in and have access to only their doc. I could then give access to coaches to the docs of their players.
Hi Fabio,
Functionality is there, but Coda is not a platform creator. You cannot create systems that have log in and such.
Lloyd
Thanks Lloyd. Played around with it and can see the functionality is good. Pity about the login as would have been fun to do
