# Chinese input dissappears!
**URL:** <https://connect.superhuman.com/t/chinese-input-dissappears/36111>\
**Category:** Bugs\
**Created:** [December 15, 2022, 10:17am UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111 "2022-12-15T10:17:57Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![jointwell\_asia](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/jointwell_asia/32/31763_2.png) [@jointwell\_asia](https://connect.superhuman.com/u/jointwell_asia)\
**Post date:** [December 15, 2022, 10:17am UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/1 "2022-12-15T10:17:57Z")
</div>
chinese input just vanishes after input, the only is to copy and paste text into the doc or the tables!
**Author:** ![Nad](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/nad/32/26972_2.png) [@Nad](https://connect.superhuman.com/u/Nad)\
**Post date:** [December 16, 2022, 1:05am UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/2 "2022-12-16T01:05:10Z")
</div>
Hi,
Just tried and Chinese input works as usual for us here. Are you using the standard pinyin input method? Some colleagues in the past experienced similar issues and they caused by external pinyin keyboard apps not playing nice (eg. 搜狗输入法).
**Post date:** [December 16, 2022, 3:21am UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/3 "2022-12-16T03:21:19Z")
</div>
Hi Nad, thanks for the super quick response, actually i use the GOOGLE INPUT TOOLS , chrome extension for input. its the official multilingual tool from google… im using the cantonese input…
[Google Input Tools - Chrome Web Store](https://chrome.google.com/webstore/detail/google-input-tools/mclkkofklkfljcocdinagocijmpgbhab?hl=en)
**Post date:** [December 16, 2022, 5:40am UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/4 "2022-12-16T05:40:51Z")
</div>
Ok, I am not familiar with Google Input Tools - but my suggestion would be to first disable these and use instead the default input method provided by your operating system. MacOS and Windows both provide a Cantonese (Traditional) input method. if these works fine (as they do for me), then the issue is probably with the Google Input Tools and not with Coda.
for reference: I am using the standard pinyin keyboard on Mac Os and run coda in Chrome, and I have no issues.
**Post date:** [December 16, 2022, 12:19pm UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/5 "2022-12-16T12:19:45Z")
</div>
ok thanks yes i confirm i can use chinese input without any issues on the windows native keyboard input… the chrome extension is having issues. thanks
**Author:** ![system](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/system/32/24484_2.png) [@system](https://connect.superhuman.com/u/system)\
**Post date:** [December 19, 2022, 12:19pm UTC](https://connect.superhuman.com/t/chinese-input-dissappears/36111/6 "2022-12-19T12:19:59Z")
</div>
Closed on December 19, 2022, 12:19pm UTC
