Coda AI vs Notion AI
@Jean_Pierre_Traets was kind enough to share a link to the following article about the Notion AI capabilities.
This is an excellent article that reveals a lot of ‘under the hood’ details about Notion AI.
And, although we do not have access to the same ‘under the hood’ details for Coda,
the fact is that Coda executes an almost identical process when you do prompting inside your Coda doc (as far as I can tell - and I have deployed a great many Coda AI Agentic docs).
Whether they are using a sophisticated incremental-update mechanism for a vector database, or just stuffing the context window with the text, I do not know. But it works!
In fact Coda AI has a much more flexible system for executing prompts.
THE SIDE-BAR AI:
This can be set to use your entire document, or the current page, or your current selection, or just the web.
This is exactly like the Notion AI described above
But we do not know exactly what tools and processes it uses, but it works the same!
THE CANVAS AI-BLOCK:
Extremely flexible, as you can enter your prompt and refer to things in your document.
You can enter formulas that use values in your tables and control-values.
Or you can use the @ symbol to select pages to be used in your prompt.
So it works very much like the Notion AI described above.
But with a lot more control over the whole process
THE AI TABLE-COLUMN:
This is the one I use the most often.
You can build your prompt with formulas.
So you can include value from your tables, etc.
For some reason is does not let me refer to entire pages :slightly_frowning_face:
For these three types of AI to work, Coda has implemented its own RAG system under the hood.
They just have not revealed what that is
and finally…
When we want to build our own Superhuman Go Agents (via Packs),
we will also be able to build our own vector databases
using the Sync Table mechanism.
This is very similar to the Pinecone vector DB mentioned in the Notion article.
But Coda has not revealed the inner details,
yet it works exactly the same for RAG use cases..
So Coda is in no way behind in this ‘race’.
They just are terrible at letting the world know that.
We (Agile-Dynamics) also build solutions in Notion, but we cannot build the kinds of Agentic Workflows in Notion that we can build (easily!) in Coda.
@Bharat_Batra1 or @noah, care to comment?
:red_circle:➤𝖒𝖆𝖝
Yep. So close, yet so far. Great assessment!
While many use cases with native Coda AI work well, some don’t and I think it’s simply the legacy artifacts of a two-year stasis of the integrated AI architecture. I’m not comparing Coda AI performance with Notion and instead, comparing it to the new Coda MCP when utilized by a more advanced agentic stack and LLMs such as Gemini 3 and Anthropic models.
Notion just released its latest AI advance: Custom AI Agents.
One of my clients was involved in the beta test program and developed several pretty powerful use cases for their business.
This represents the direction that we are all hoping to see Superhuman/Coda pursue.
It is to be hoped that the anticipated announcements will close the (now growing) AI chasm between Coda and its competitors (Notion and Airtable).
While this new AI agentic capability of Notion is very attractive, I remain committed to Coda because the rest of Notion’s abilities are so far behind Coda of automations - their formula language and its tiny set of functions, plus the absence of proper action formulas and buttons - means that it is not worth making the switch.
But I fear that less sophisticated makers who do not value those advanced aspects of Coda may be tempted to cross the chasm.
Fingers crossed for the anticipated announcements from Suprhuman/Coda.
:red_circle:➤𝖒𝖆𝖝
