Hi all!
The following doc is a collection of community posts that provide various doc solutions. This is a great place to find some ideas for how to build out different things in your doc, or solve problems you’re running into.
What’s a solution?
Solutions can help us solve problems in our doc.
A solution…
- Solves a problem in a doc
- Gets you from Point A to Point B
- Changes the nature/status of an element in the doc
In a nutshell, a solution is an answer to a problem you want to solve in your doc build.
This doc will be periodically reviewed and added to. If you have a solution you want to share with the rest of the community, be sure to add it here!
