Is CODA considering an interface like the one just launched by airtable?
Hi @Luis_Matos
I had to check what was an Airtable Interface (
), but I think you could build similar displays with the upcoming Canvas Layout feature (actually in Beta) which will allow you to put (any) content side-by-side on the canvas
Edit: If you’re curious about Canvas Layout (which is just a part of Coda future New Editor
), you can check the replay from the very last Block Party, where it was announced
here
Is it possible to have access to the Canvas Layout Beta?
Hi @Luis_Matos
Well, joining the beta would be useless at this point apparently
: The feature should be launched soon
