Coda Feature Request: Export Detail View Tables to PDF
Hello,
We frequently use the Detail view for our clients’ documentation, where we display all the necessary columns and their values.
However, we encounter difficulties when exporting lists that include Detail views and their content. There is no reliable way to export the entire content of a Detail view easily; the only workaround is to separate each row into an individual Detail view table. For example, if you have 15 rows in one Detail view, you must create 15 separate views to export them.
Therefore, we would appreciate a simple and efficient method for exporting Detail views to PDF.
If you need any additional information or examples of our documentation, I would be happy to provide them.
Thank you,
David
I’m in the process of transitioning over here from the AirTable world, and used DocsAutomator for most of my print media setups. There are a number of other pack options for PDF output here that I have looked at (none that I like as much as DocsA) such as DocuMint, pdfGenerator and docMaker. These might work for you?
Are there any news here?
