My business is mostly conducted among âRegulated Industryâ clients in Aerospace Engineering (FAA regulated), Clinical Research (FDA regulated), and Financial Services (SEC regulated).
So I have been using Coda in these contexts for years with excellent results. We have migrated compliance teams from using MS SharePoint, Google Docs, and various proprietary document repository products.
Coda provides an excellent vehicle for building your own highly tailored repository of managed documents, which also contain Tables, Formulas, Automations, and Integrations with other applications.
However, this is only worthwhile if you are prepared to put in the effort to develop and maintain your own tailored solution - otherwise, it may be cheaper and easier to stick with an off-the-shelf solution.
But the rewards for building your own specific solution that matches your business requirements are well worth it in my experience.
Coda does not come out of the box with all the mechanisms required to implement âControlled Documentsâ for compliance with ISO9000 regimes.
For this, you need to apply your own policies on top of the default Coda platform. The most important one is the need to have full version control on your controlled documents.
For this, we always add a version number to the end of every document title. And we ALWAYS copy the current version and modify that copy to generate the new version.
We have added our own document control table to each document to record who changed it, why, when, and with what approval process.
To ensure that users always access the correct document version, we keep a âMaster Documentâ for each department that contains the links to the latest documents. That way, we can control which version is âliveâ at any time. And we can roll-back if needed. It also provides the document change history needed by auditors.
An alternative approach might be to only rename the OLD versions of the docs and move them to a separate folder where users wonât see them.
But we have found the âMaster Docâ provides a place for keeping a lot of the meta data about policies and procedures, and document versions, etc.
We have found that the armies of auditors that must review and approve our controlled documents LOVE this approach to document control.
Coda also lets you use a single document to store the process definition AND the usage data needed by auditors to show that the procedures have been followed, etc.
One difficulty you will need to address is the inability of Coda to easily separate the DATA tables from the rest of the document, so moving to a new version of a document often requires us to kick users out of the live document while we migrate to the new version. (We hope Coda will be addressing this soon with âworkspace tablesâ that reside outside the documents.)
Reach out if you need any further help.
Respect,
â¤đđđ
