Hi guys,
Is there any Coda Formula I can use to forecast the possible Q4 2023 Total Leads, Active Discussion, Converted Events and Event Total based on these 2021, 2022, and YTD 2023 data?
Thank you ![]()
Hi guys,
Thank you ![]()
Hi Renee
Short answer, there are no βforecastβ formulas in Coda. Forecasting is more of an app, than what it is a simple formula.
For example, do you simply want a moving average to be extrapolated? Do you want newer period to weigh more heavily than older periods? If so, by how much? For how long?
Is there a seasonality type of aspect that needs to be taken into account?
P
Really well put @Piet_Strydom
If you give more info the community can help you out though!
