I’ve read that the CODA pack limit is 4mb? Not only is that REALLY low but it seems to be calculating incorrectly? I’ll hit an endpoint with Postman and it will report less than 1MB returned but I’ll still get throttled. Is there a way to raise the limit on my coda pack? Its only internal and only runs once a day so it should be pretty light.
Related topics
| Topic | Replies | Views | Activity | |
| INTERNAL Fetch Error: Over limit | 3 | 634 | May 8, 2023 | |
New API limit - 1,000 rows? Alternative services or workaround
9 | 2475 | January 22, 2020 | |
| API rate limitations | 2 | 1172 | September 8, 2023 | |
| Add document size (MB) metric | 2 | 1079 | January 26, 2021 | |
Export Coda to Airtable
3 | 826 | October 30, 2020 |
