I am developing some custom packs in coda. I am good at adding the formulas and the sync tables. I am bit lagging in adding a button in pack. Could anybody please let me know how to add a button in the coda pack with some code syntax ? Thanks in Advance
Hey, @Elam_Jaybal .
All you have to do is add the line isAction: true, to your code
You can check samples here bellow
Hi Breno,
Thank you so much. It works.
Thanks,
Elam
