Concatenate without @ link?
I have a concatenate formula that I’d like to output only text, but it’s creating @-links to the parts of the formula that reference other tables. Any way to kill the links?
EDIT: For noobs (I had to play around with it till I figured it out), I added this to the end of the item I wanted to remove the link for: Type.ToText() (i.e., not to the end of the whole formula)
what about adding ToText() at the end?
cheers ,christiaan
Heeeeey, that worked! Thanks so much!!
If @Christiaan_Huizer’s solution worked, could you mark his answer as the solution by clicking the checkmark?
