Hi! I am having such a hard time putting my question into words to search for it, and it is probably a very simple answer. So, I thank you for your patience and help in advance
[TLDR; I am looking for a formula that says if the subtask name is the same as the task name, give me this color].
I have the classic tasks and subtasks tables, and I want to use the subtasks table (grouped by task) as the main view for my team, so they can see all the subtasks. I have an automation set up to auto-add a subtask to a task if there isnโt one already so that they all show up in the subtasks table. What I would like to do is set up a conditional format rule to highlight any rows that have the same task and subtask name (essentially any task that technically does not have any subtasks).
So, I am just looking for a formula that says if the subtask name is the same as the task name, give me this color. Unfortunately, subtask = task is not working. Or, if a task group only has one subtask. That would work too!
Thank you!
