Weird! Others has success playing and other also said it wasnât working.
Iâll try another way!
@Jeremy_Sanchez Iâm glad the LinkedIn post worked! Looking forward to seeing the agent submissions
Hello, Everyone.
Jesus from Simpladocs here. As with every single project manager Iâve had experience with, salespeople overpromise, and I, as the delivery driver, have to bend backward and forward to make a project work; therefore, I created the Sales Guardrail, which looks into business rules and prevents a salesperson from committing to something against the Businessâs Rules.
Link to the agent here
Sharing evidence of completion for the course
Here is my first attempt at building an agent! Itâs very simple, but it solves a real need for me as I work to turn Superhuman Docs into my second brain and research hub.
Highlight Librarian
When I find something noteworthy online, I no longer need to open a new tab, find the right document, and figure out where to paste the information. Highlight Librarian takes my highlighted text and files it in the most relevant Superhuman Doc so I can collect my thoughts in one place, distraction-free. In addition to direct quotes, I can capture my own notes and summaries in the moment. It remembers which Doc each article/source belongs in, automatically groups text under a source-specific heading, and prevents duplicate entries.
I no longer need to find a relevant document, open it, locate where to copy/paste my thoughts, and constantly switch between tabs. There are other tools for saving highlights, but this one is truly tailored to my needs and lets me instantly add content to Superhuman Docs. In addition, Iâm not limited to quoted text; I can just as easily jot down my own notes and send them to my agent.
In summary, this agent helps me stay focused on reading, researching, and developing ideas that I can revisit, build on, and connect with ideas from other sources, all without interrupting my flow. Whatâs more, it helps me link ideas in ways I might not otherwise notice, turning scattered research into organized knowledge. As I use this more, Superhuman Docs will become an interconnected second brain that helps me think more deeply and spot connections across my research.
It runs when I run the agent and paste text into the side panel.
Superhuman Docs <> info from the webpage youâre reading
Certificate of Completion: https://verify.skilljar.com/c/i5g3cuuvq36t
Hi Ruggy - just following up on the DM side of things as I donât think I have seen anything yet. Thanks!
Very cool ideas, everyone! Mine are a bit more personal since I already have 34 agents built before this contest started, most of which are focused on making my life easier, haha.
Hi everyone! Iâm Erin, a developer at SimplaDocs. I spend my days building client systems in Superhuman Docs, and if you do client work, you know this one: a client drops âoh, can we also addâŚâ into Slack, someone says âsure, no problem,â and three weeks later the budgetâs gone and nobody can say where it went.
Itâs almost never one big change request. Itâs a dozen tiny ones nobody flagged. So I built an agent to flag them for me.
Every weekday morning, it reads my client Slack channels and email, pulls out anything thatâs actually a request for work, and checks it against the scope we signed. Each one gets logged in my doc as In scope, Out of scope, or Unclear, with the exact SOW line it relates to and a link back to the original message.
Then I get one Slack DM with what it found. If I have a client meeting that day, the DM also includes a quick brief: the contract, this monthâs tally, and every open item I should bring up on the call. I walk in knowing exactly what to raise, instead of scrolling back through threads five minutes before.
The part I care about most: it never decides for me. It never messages a client, never posts in their channels, and never sends email. When it isnât sure, it marks the request Unclear and tags the project owner instead of guessing. I set the Status. And when I dismiss something and write down why, that reason becomes precedent, so the next time a similar ask comes in, the agent points back to my call.
How it runs
It also helps with setup in chat. Paste in a SOW and say âset up a client from this SOW,â and it breaks it into scope items. âMap my docâ checks your tables before the first run. Neither writes anything until you approve.
Connectors: Superhuman Docs (read and write), Slack (read, plus send message for the DM), and Gmail/Outlook & Calendar (read only; every write tool is off or set to ask).
Everything lives in the Scope Creep Spotter doc. Copy it, clear out my example clients, and add your own client, project, and scope. Then head to Set Up the Workflow. Two buttons copy the agentâs description and instructions, already pointed at your copy, so you just paste them into a new agent in Go. Chat âmap my doc,â wait for Ready, and youâre set.
Hereâs my certificate: https://verify.skilljar.com/c/dh27wuvpqiod
Thanks for taking a look!
Erin Bunge
Developer at SimplaDocs
Topic Planner: turn expert guidelines into a reviewable plan, one topic at a time ![]()
Hi all! Felipe here, Systems Architect at SimplaDocs. A pattern keeps showing up in the content-production systems we build: an expert writes a guide (âevery topic needs X activities of these types, in this order, ending with this kind of taskâ), and someone has to apply it by hand, topic after topic. Itâs slow, itâs easy to get subtly wrong, and it ties up the very people whose judgment you need elsewhere.
This agent applies the guide so the expert can focus on reviewing. To show it working, I built it on a real-world style example: a multi-level music course, where each topic is planned into 20â30 activities (ear training, notation, theory, playing, composing) that build toward a final performance task.
Agent name: Topic Planner
What it does:
For each topic in a Superhuman Doc, it reads the topicâs inputs and the expertâs Planning Guide. Then it writes a complete, structured plan: one row per activity, each with:
It finishes with a coverage summary so the reviewer can check the plan at a glance. In the music example, the inputs are key terms, theory focus, style and repertoire, and the performance task.
What it gives the team time to focus on:
The expert stops being the bottleneck for mechanical rule-following and spends their time where it matters: reviewing plans, adjusting sequences, and improving the guide itself. Every plan follows the same rules, whoever triggers it.
How it works:
Apps and connectors:
Built to be reused, and to protect the expertâs know-how:
Try it yourself
Open the Topic Planner template and follow its Set up page:
The How to use this doc section on the same page walks through the full cycle.
Loom: Automating Music Course Activity Planning | Loom
How it fits the criteria
Getting Started with Superhuman Go Certificate: https://verify.skilljar.com/c/o267ek352s7n
Felipe Arnhold from SimplaDocs
I live between two cities. Bilbao is home â rainy, layered, smart-casual. Malaga is my flat â sunny, linen, espadrilles. And somewhere in between, Iâm usually travelling with a capsule bag and a vague plan.
For a long time, getting dressed felt like a small but surprisingly draining decision. Not because I donât love clothes â I do, deeply â but because âwhat should I wear today?â is actually four questions at once: Whatâs the weather? What do I have with me? What am I doing today? What feels right? Every morning, before coffee.
So I built an agent to handle it. I call her Parlamoda.
Parlamoda handles my daily outfit decision from start to finish. Each morning I ask her one question: âWhat should I wear today?â
She takes it from there:
She never suggests a trench coat when Iâm in Malaga in August. She knows I have a capsule wardrobe there, not my full closet. She knows Bilbao in October means layers. That context is what makes her actually useful.
Mornings. Properly.
That sounds small, but the cognitive load of âwhat to wearâ is real â especially when you split your time across climates and wardrobes. Parlamoda removes a low-value decision from my day and gives me back the mental space for things that actually matter: the work I want to do, the people Iâm seeing, the coffee I want to drink slowly.
Over time, she also learns. I rate each outfit and leave feedback after wearing it. That data builds a picture of what I actually reach for versus what sounds good in theory. Eventually, she wonât just suggest â sheâll know.
Parlamoda runs on demand â I trigger her each morning by asking the question. Hereâs what she does, step by step:
After wearing it, I give it a rating out of 5, and leave any notes. That feedback loop is how Parlamoda gets better over time.
Parlamoda is built inside Superhuman Docs and runs through Superhuman Go. The whole system lives in a single doc â a Wardrobe table with photos, labels, and location tags; an Outfit Log that auto-fills with each suggestion; and a Location Profiles page that gives Parlamoda her geographic intelligence.
To set it up yourself: duplicate the doc, connect Superhuman Docs, Weather, and your Calendar in Superhuman Go, and paste the ready-to-use agent prompt from the Parlamoda â Superhuman Go Agent Setup. Then ask: âWhat should I wear today?â
The more you fill in your wardrobe, rate your outfits, and keep your location profiles up to date â the more Parlamoda feels like she actually knows you.
Kaixo! Iâm Ainara Bilbao, from beeq â the Superhuman partner in Europe. I split my time between locations, which means Iâm constantly switching climates, wardrobes, and headspaces. This is the agent I built to make my mornings a little easier.
Love this agent ! I love web clippers and this agent is nice to replace them using go ![]()
Love this ! We face a similar challenge in our nonprofit: keeping knowledge accessible and up to date as volunteers come and go, and projects evolve from year to year.
Thanks for sharing your use case @Kearsten_Morgan, itâs inspiring to see how youâre approaching this ! ![]()
I am myself planning to submit an agent to help onboard volunteers by the end of the day ![]()
Hello, Guys.
Happy Tuesday, I was informed that agents are not yet shareable, so I shot this Loom showcasing its capabilities.
The value I see here is that it fits naturally into a salespersonâs flow and role; the agent fires proactively when drafting a quote, whether thatâs in an email, in a Google document, or within the doc. Not only that, but it tells you exactly what you did wrong and how to fix it; the errors are concrete and actionable (17% discount is over the 15% threshold). Itâs not intrusive enough to block email sending, as the salesperson may still want to trigger a different flow that allows him/her to offer the customer a bigger discount via the approval flow.
Please let me know your thoughts
Meet Fern: the resource planner ![]()
Hi all! Bhavya from SimplaDocs here.
Every agency runs on the same three questions: Whoâs free? Who fits this request? Can we book them without overloading them? Answering means opening tables, subtracting hours and remembering time off, over and over.
Fern does that math for you. Ask in plain language and get a short, Slack-friendly answer: one line with hours free, utilization and skills.
Assigning someone is just as easy, and just as safe. Fern asks for any missing details in one message, checks the person and client, and warns you about overbooking, time off or Paused clients. It then shows a one-line preview and writes only after you reply confirm.
People stay in control:
Connect fern to where ever your Agency Data lives and Fern does the Job
Demo Data Doc and Agent Instructions
Fern recommends. People decide.
Hey Sasha!
DMing you now
Thanks @Jeremy_Sanchez!
How did you like the course?
Welcome to the community, @Kearsten_Morgan!
This is such a great use case. I love how thoughtfully you approached this, especially separating the standard processes from partner-specific requirements, linking back to the original documentation, and flagging anything that still needs a human check.
And thank you for sharing such a detailed template! âLess searching. Fewer interruptions. More time focused on the client.â really says it all.
Best of luck as we inch closer to the review process!
There are so many ways to make agency life easier, and your Fern agent is a great solution! Removing the guesswork of finding the right person while still checking capacity, time off, and client status can save a lot of time. Thanks for sharing, @Bhavya_Dangayach and good luck in the contest! ![]()
OMG where has Scope Creep Spotter been all my life?!?!
This is seriously something I have had to do a delicate dance around my entire career (not here at Superhuman, of course @Emma_Wyatt
), and I know Iâm not alone in balancing the struggles of knowing when is ok to push back, delegate, etc⌠Absolutely in love with this one, @Erin_Bunge ![]()
Best of luck with the next phases!
@Felipe_Arnhold I like how you set this up. The agent reads the guide fresh each time, checks its own work, and stops at the plan instead of generating the content. That keeps the expert in charge while still taking a lot of repetitive work off their plate (e.g., exactly what we like to see in all Superhuman use cases!).
Keeping the guide private is smart too. It protects the expertâs know-how, and the workflow still works for courses, onboarding, certifications, and other structured content.
One question: when reviewers edit the generated plans, do you see those edits feeding back into the guide over time?
@Ainara_Bilbao this is a great build! Getting dressed across two climates and two wardrobes is a real problem, and Parlamoda handles it well. And not to foreshadow too much, but this agent would come in handy in San Francisco, where one minute youâre getting sunburned and the next youâre freezing as the fog rolls in. ![]()
Good luck in the contest!
Canât wait to see it, @Eva-Automation! You have until the end of today to get it in ![]()
