Copy and Paste from Apple Numbers
If you come from a Mac environment you are already partly thinking in a Coda structure and creating pages with elements if you use Apple Numbers
Unfortunately if you copy and paste all of your hard work from Apple Numbers you get the correct number of rows and columns, just with no data contained within them
We will have to check this out and see if there is a fix.
For the moment though, exporting as a CSV and importing into Coda should do the trick.
