How long should copying a template generally take? I’ve gotten the spinning wheel icon for about 7 minutes now
Dear Kara,
Should be immediately available and is not so much depending on your Internet connection as you work on the server at Coda.
Just try again and start to enjoy Coda.
Kind regards,
JP
Hi Kara, are you still facing an issue here? As @Jean_Pierre_Traets mentioned it should be pretty immediate. Is it a particular template or all?
Thank you both! It was a portfolio template set - it took about 2 hours but it finally succeeded. Other template sets were totally fine.
Hey @Kara_Lumley, was it a template you were trying to copy from the public gallery?
Yep, the Cryptocurrency Portfolio Tracker
all is well now though
