How can I count the total number of “Yes” and "No"s across a dropdown?
Hi @Christien_Louviere
One way to do this would be to use something like …
For the Yes :
(See the formula in the field [Total - Yes] in the sample below)
ListCombine(
thisRow.[Select 1],
thisRow.[Select 2],
thisRow.[Select 3]
).CountIf(CurrentValue = Yes)
And for the No:
(See the formula in the field [Total - No] in the sample below)
ListCombine(
thisRow.[Select 1],
thisRow.[Select 2],
thisRow.[Select 3]
).CountIf(CurrentValue = No)
… where in both formulas, CurrentValue represents each specific text value currently selected in each select list in thisRow … which is then counted if it’s equal to Yes in the 1st formula and No in the 2nd one ![]()
I hope this helps ![]()
