Creating a Webhook Callback for Meta's WhatsApp API Using a Coda Pack
Hi community,
I’m trying to implement a webhook callback for the Meta (WhatsApp Business) API directly within a Coda pack. Currently, I have a working solution on Glitch that uses an Express server to receive incoming WhatsApp messages and automatically save them to a table in Coda.
Here’s how the flow works on Glitch:
  1. Meta sends a POST request to the server’s endpoint whenever a new WhatsApp message is received.
  2. The server verifies the message, extracts the text, and sends it to a table in Coda via Coda’s API.
  3. The server responds with a 200 OK status code to confirm the webhook reception.
My goal is to replicate this flow within a Coda pack, eliminating the need for an external server like Glitch. Specifically, the pack should:
  • Configure a webhook with Meta’s API to receive messages.
  • Extract relevant data from the message (sender, text, timestamp, etc.).
  • Automatically sync the data into a Coda table.
Here’s the current code I’m using in Glitch:
import express from "express";
import axios from "axios";
const app = express();
app.use(express.json());
const { WEBHOOK_VERIFY_TOKEN, GRAPH_API_TOKEN, CODA_API_TOKEN, CODA_DOC_ID, PORT } = process.env;
// POST route to handle incoming WhatsApp messages
app.post("/webhook", async (req, res) => {
  console.log("Incoming webhook message:", JSON.stringify(req.body, null, 2));
  const message = req.body.entry?.[0]?.changes?.[0]?.value?.messages?.[0];
  // Verify that the message type is "text"
  if (message?.type === "text") {
    const messageBody = message.text.body; // Extract the message text
    try {
      // Send the message to the Coda table
      await axios({
        method: "POST",
        url: `https://coda.io/apis/v1/docs/${CODA_DOC_ID}/tables/Registro_Mensajes/rows`,
        headers: {
          Authorization: `Bearer ${CODA_API_TOKEN}`,
          "Content-Type": "application/json",
        data: {
          rows: [
              cells: [
                  column: "Mensajes",
                  value: messageBody,
      console.log("Message saved to Coda:", messageBody);
    } catch (error) {
      console.error("Error saving the message to Coda:", error.response?.data || error.message);
  // Respond to WhatsApp with a 200 status code to confirm the webhook
  res.sendStatus(200);
// GET route for initial webhook verification
app.get("/webhook", (req, res) => {
  const mode = req.query["hub.mode"];
  const token = req.query["hub.verify_token"];
  const challenge = req.query["hub.challenge"];
  if (mode === "subscribe" && token === WEBHOOK_VERIFY_TOKEN) {
    res.status(200).send(challenge);
    console.log("Webhook verified successfully!");
  } else {
    res.sendStatus(403);
// Start the server on the specified port
app.listen(PORT || 3000, () => {
  console.log(`Server is listening on port: ${PORT || 3000}`);
Variable Breakdown:
  1. WEBHOOK_VERIFY_TOKEN: A token used to verify that the webhook request comes from Meta. It is compared with the value sent by Meta during the webhook setup.
  2. GRAPH_API_TOKEN: The access token for Meta’s API that authorizes requests to WhatsApp endpoints.
  3. CODA_API_TOKEN: The access token for Coda’s API to allow writing data to a specific table.
  4. CODA_DOC_ID: The ID of the Coda document containing the tables where the messages are stored.
  5. PORT: The port on which the Express server runs. Defaults to port 3000 if not defined.
Questions for the Community:
  1. Is it possible to replicate this flow directly in a Coda pack?
  2. How can I set up the pack to receive webhook callbacks, process them, and sync the data into a Coda table?
  3. Are there any examples of webhook setups in a Coda pack that I can use as a reference?
Any guidance or suggestions would be greatly appreciated. Thanks in advance! :blush:
Hello @Jose_Manuel_Canadas
You can set up an automation in your Coda doc using a webhook trigger. This will generate a URL and API token that you can use with the Meta endpoint. The Coda automation receives a JSON payload, which can be decoded directly to populate any table in your doc.
Let me know if this approach meets your needs.
Best regards,
Arnhold
As @Felipe_Arnhold has pointed, you don’t need a pack to receive a Webhook-triggered automation and packs are not meant for that. But you do need to authenticate the webhook before sending it to Coda. If you can’t set up a bearer authentication within Meta , you can’t eliminate the middleman.
