Cross-doc row limit
Is there a 1000 row limit for cross-doc tables on the Pro Plan?
You’ll have access to both options listed there with the Pro Plan.
The Team Plan gets you Cross-doc Actions, where you can write back to the original table.
Hello @Ben_Lee ,
About the write back function, is there a sample doc somewhere showing how this works? Or is there a bit more documentation about cross doc formulas (on the team plan)?
Thanks,
Greetings, Joost
Here’s our help center article on cross-doc actions.
https://help.coda.io/en/articles/3506663-how-to-use-cross-doc-actions
