# Details view toggle between "large" and "right panel" views
**URL:** <https://connect.superhuman.com/t/details-view-toggle-between-large-and-right-panel-views/11755>\
**Category:** Product Feedback\
**Created:** [October 30, 2019, 2:39pm UTC](https://connect.superhuman.com/t/details-view-toggle-between-large-and-right-panel-views/11755 "2019-10-30T14:39:11Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![ABp](https://avatars.discourse-cdn.com/v4/letter/a/c67d28/32.png) [@ABp](https://connect.superhuman.com/u/ABp)\
**Post date:** [October 30, 2019, 2:39pm UTC](https://connect.superhuman.com/t/details-view-toggle-between-large-and-right-panel-views/11755/1 "2019-10-30T14:39:11Z")
</div>
Would love to see a basic toggle allowing minimizing to the right panel of the row details view. A lot of apps have this capability. The toggle would be where I indicated in this primitive mock-up attached
 ![Untitled%202](https://global.discourse-cdn.com/coda1/original/2X/7/7104c34acf19930bca06bec797a1641414b5015e.png)
Some other apps have this capability, Clubhouse for example just released it:
 ![image](https://global.discourse-cdn.com/coda1/original/2X/9/92d70060acfa0d8211bb0ec079fbdbffad6b2c08.png)
You can see here the a tooltip which indicates that you can click on that toggle to make the card wider or more narrow.
And I think this relates to this post as well,
> [@Shortcut to clickthough to View Details directly](https://connect.superhuman.com/t/shortcut-to-clickthough-to-view-details-directly/7055/10):
> Okay, so I made something but Coda has moved something so it doesn’t work anymore sob@jaime is it from your service? So here is what I’ve done before: [image] It is a bulleted list that takes rows from a table. What was cool before today, is that I could add a “Done” button and from by base table move the Done button at the beginning of the table (the column) and hide it (because I dont use this button in the base table). This caused the button to be at the top of the hovered card. Now,…
which talks about your guys’ great preview functions when you hover over stuff across Coda - that I have no issue with and I think has been really well built so far, and an outstanding way to speed around Coda without having to click too much.
Thanks guys and hoping to see this relatively easy addition soon!
