# Does anyone knows if there is a plan for one drive integration?
**URL:** <https://connect.superhuman.com/t/does-anyone-knows-if-there-is-a-plan-for-one-drive-integration/10175>\
**Created:** [August 31, 2019, 2:14pm UTC](https://connect.superhuman.com/t/does-anyone-knows-if-there-is-a-plan-for-one-drive-integration/10175 "2019-08-31T14:14:24Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Maydan\_W](https://avatars.discourse-cdn.com/v4/letter/m/9d8465/32.png) [@Maydan\_W](https://connect.superhuman.com/u/Maydan_W)\
**Post date:** [August 31, 2019, 2:14pm UTC](https://connect.superhuman.com/t/does-anyone-knows-if-there-is-a-plan-for-one-drive-integration/10175/1 "2019-08-31T14:14:24Z")
</div>
We are a new startup and until now we had been working with GSuite but we found out we do need to use Office 365 instead of G-Suite.
Is there a way to use [Coda.io](http://Coda.io) with One Drive?
Is there a plan for it in the foreseen future? (we could be the beta tester)
I love Coda and would very much like to find the way how we can keep it
Thanks
**Author:** ![Jean\_Pierre\_Traets](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/jean_pierre_traets/32/16275_2.png) [@Jean\_Pierre\_Traets](https://connect.superhuman.com/u/Jean_Pierre_Traets)\
**Post date:** [September 1, 2019, 7:42am UTC](https://connect.superhuman.com/t/does-anyone-knows-if-there-is-a-plan-for-one-drive-integration/10175/2 "2019-09-01T07:42:20Z")
</div>
Dear @Maydan_W,
It’s on the roadmap, but not clear when expected to be rolled out
