Does anybody know of a way to get the driving distance between two addresses in Coda? I’m guessing it’s not possible using just Coda?
hi @Allen_Ormond1 , indeed this is not yet possible for it requires Google Directions.
There is an experimental function that is visually appealing and has the very same name, but does not deliver the output (driving time, driving distance) as number or text, It is GoogleDirections()
It is rather easy, it shows a map.
best, Christiaan
Hey @Allen_Ormond1 ,
I’ve been tinkering with the Pack SDK yesterday, and have built a pack that gives you the distance between 2 addresses in a formula.
Link: Coda | Driving Distance
Demo Doc: Road Trip Planner
Wondering if this is what you’re looking for.
Thanks,
-K
hi @Kenny , thanks for the input
in Coda we already have the function Distance() and Location()
Distance(location1, location2, unit)
Returns the distance (in kilometers) between two locations (lat/long) on earth using the Haversine formula. I guess you used this one:
The driving distance requires access to a specific and expensive API.
Cheers, Christiaan
Yup! The distance from the pack is the driving distance (& duration) between two locations - Rather than what was returned from Distance(...) formula.
hi @Kenny , thx!
I did not notice that you return the distance in miles, we use the metric logic (Km). Once I know this, we can work around it (but adding the Km option would be wonderful, I did not see how to do it).
concerning the time, it is a driving time that does not take into account the traffic itself, right?
merci, Christiaan
RE: Showing metrics (Meters) vs versus miles
RE: Driving time - Does it account for traffic?
(A bit of context around why I created the formulas: I use Coda for road trip planning, and the function mainly helps me figuring out how I should account for driving time per day. On the day of the road trip, I’ll usually check for real-time traffic in the morning & between each stop, and adjust my plan accordingly.)
it is wonderful contribution @Kenny ,
the driving time would be rather practical for alerts, but since we have already the distance and normal driving times, it all works for well for me. I do some work for transportation companies in Coda and distance (fuel, etc, driving time) plays an important role. Your tool will save me some time!
many thx again, cheers, christiaan
