# Dropdown autocomplete not working properly in text column
**URL:** <https://connect.superhuman.com/t/dropdown-autocomplete-not-working-properly-in-text-column/55005>\
**Category:** Bugs\
**Created:** [April 5, 2025, 5:13pm UTC](https://connect.superhuman.com/t/dropdown-autocomplete-not-working-properly-in-text-column/55005 "2025-04-05T17:13:46Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![Felipe\_Griebel](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/felipe_griebel/32/28316_2.png) [@Felipe\_Griebel](https://connect.superhuman.com/u/Felipe_Griebel)\
**Post date:** [April 5, 2025, 5:13pm UTC](https://connect.superhuman.com/t/dropdown-autocomplete-not-working-properly-in-text-column/55005/1 "2025-04-05T17:13:46Z")
</div>
Below is an example of the bug, it started a while ago.
Whenever I start typing an entry, formerly it would start filtering a list of autocomplete suggestions after each character type, making the list smaller and smaller. This was good for me, because I could get to the information quickly. Now, it seems like the mechanism changed, where it registers only the first letter I type (in the example case it’s ‘b’), if I erase it without leaving focus of the cell and start typing other stuff, the dropdown just gets stuck in the suggestions for the first letter always.
 ![image](https://global.discourse-cdn.com/coda1/original/3X/6/d/6d2efbc362b141d3a84859c507f49f0655ac1f4a.png)
