Easiest way to delete item from a list iteratively
Hey all,
I’m using a FormulaMap to iterate over every row but the one I’m on, so something like
Table.Filter(CurrentValue!=thisRow).FormulaMap()
Then I want to go and delete my name from a list. I wanted to use .Filter() but that doesn’t work if my name isn’t on the list. In that case I have to use an IF() statement which gets super clunky. I was hoping something failed gracefully. I tried thisRow-User() but it deletes everything in the column.
Beyond the IF() statement being clunky and looking for something cleaner, I also get an “Unable to execute invalid action” when trying to do a Null result on a FormulaMap, so I had to do another ModifyRows() for a fake column just to make it work. How can I fix that??
Test.Filter(
IF(CurrentValue.Voters.Contains(User()),
ModifyRows(
CurrentValue,
Voters,
Voters.Filter(CurrentValue!=User())),
ModifyRows(CurrentValue, [Column 3], “good”)))
Dear @Chase_Schwalbach,
@Paul_Danyliuk has made a detailed tutorial on iterator tables in the below link:
I am rather sure that this a good start point :rocket:
@Chase_Schwalbach no need for iterator table — this works, not sure why you had problems:
thisTable.Filter(
  CurrentValue != thisRow
).FormulaMap(
  CurrentValue.ModifyRows(
    Voters,
    Voters.Filter(CurrentValue != User())
If you want to avoid modifying rows that have nothing to modify, you can further filter rows down to only those that have you as a voter; no If() required:
thisTable.Filter(
  AND Voters.Contains(User())
).FormulaMap(
    Voters,
You’d need an iterator table if you were doing some comparison within the inner Filter with the CurrentValue of FormulaMap. But in this case there are no CurrentValue context issues here.
