Hello!
Tell me please, is there any way to do coda auth in embeded block?
As I know it’s only available for google sites. Will that feature appear for all sites in future?
If yes - when do you plan to release that?
Hello!
Hi @nikita - Welcome to the Coda community! Can you give a more concrete example of what you are trying to accomplish?
I see, thanks for clarifying. Unfortunately we don’t offer the ability to sign-in to an embedded Coda doc, nor are we currently working to build that. For the time being you’ll have to link the user to the doc and have them open it directly.
