Feature request: Better automation controls
I often struggle with managing my automations:
  • the are listed in the order in which they were first created
  • the current automation controls are small and in the corner. not re-sizeable, and text often cut off. I want my opponent in Go to live small and in the corner, but not so with my automations.
I wish I could manipulate a table of them:
  • sorting by name, table they operate based on, time or row-change based, etc
  • more information at a glance
  • better views for finding failing and frequently-triggering automations, turning them on/off, etc
I continue to struggle with this. I want to be able to think more clearly about my automations, but they live small in the corner, like a player losing a game of Go.
I really need to be able to at least reorder them, and view their full names without clipping. They’re just ordered by creation date, and that’s not a very sensible order.
@silviana_amethyst we’ve just made some updates I think you’ll find handy here! You can now reorder automations, see more information about each automation from the panel, and resize the automation panel to fit more content. All the details are here!
