Hey crew! I’m trying to filter a cross-doc via a relation field, but the filter doesn’t show any of the available options. Any thoughts? ![]()
Hi, Garret! Thanks for reaching out! Looking at the screenshot it looks like the Organizations table that the relation column is using is missing from the Doc. You will need to sync that table into this doc for this to work. If you continue to run into issues I would recommend reach out to support directly. So we can have an engineer take a look at your doc.
I hope you have an amazing day ![]()
~ Luis
