Good afternoon everybody,
I am trying to embed a Coda form in an html page, and I am getting an error.
I took out just about everything, my html now looks like:
<html class="" lang="en-US" style="--vw:1.5px; --vh:14.37px; --window-width:150px; --window-height:1437px;">
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type" />
<title>Untitled 1</title>
</head>
<body>
<embed type="text/html" src="https://coda.io/form/SkyGliders-deelname-inventarisatie-2021_......." height="600" width="600">
</body>
</html>
The error I get:
Which says (in Dutch) that coda.io refused the connection. I have tried embed and iframe, both with the same result.
Does someone have an idea what of what I am doing wrong?
Greetings,
Joost
Update:
Now I realize that for embedding you need to use the coda embed reference and not the src you normally use to display a form.
For those interested: at design time, go to advanced (in the right side bar), go to the tab “embedded” and use the embed code that is presented to you.
@Coda1 :
- Why is there a logon link in the top right of this form - I imagine that when you use an embedded form you would present it (primarily) at non-coda users.
- The form title is omitted. I imagine this is not a bug, but why not leave it there (instead of ‘showing’ a pretty good chunk of empty screen?
For 1) and 2): please make these things options at design time if you feel it needs to be this way. I prefer using Coda forms for Coda docs over 3rd party solutions and I am pretty confident forms will evolve, but this type of things will lead to confusion and/or just doesn’t look pretty.
That said: if we can get a few more form features (like using our own header and footer and/or adding a logo with an hyperlink to give our users the possibility to return to our website, I would never use iframe or embed, because it is almost impossible to get it to look good (with ugly scrollbars in the frame).
@joost_mineur (or others): has this workflow changed? I can’t find the embed URL anymore for a public form, and the provided URL doesn’t work (per the original issue). When I click embed I get kicked over to making the whole doc public, which is definitely not what I want.
As far as I can tell you can only get the embed if you add the form to the canvas, get the URL, then delete it from the canvas. Seems like a bug unless I’m missing something.
I think it has definitely changed and it feels like this is not the way it should work. Please contact support to have them make a formal ticket, or to get acknowledgement that this is not working any longer.
I use a lof of forms, but I haven’t embedded them for a long time. I just give my users a link to the form and I try to make it look as good as possible.
