Form embedding not working anymore?
hi there
since the rebranding, I’m not able to embed forms from one doc into another. anyone is having the same issue or is it working? old embeds are working properly…
so here’s the form I try to embed: https://docs.superhuman.com/form/Quittung-einreichen_dPWIOR0vq0U?Status=Angefragt&Art=Quittung
here’s the result: https://www.sulgenrain.ch/quittung-einreichen-174
some browsers show just a blank page, others mention that this page can’t be displayed embedded.
I also tried to change the url from “/form” to “/embed” but this leads into a “sync page” rather than a “embed page” which fails already within the superhuman interface “Couldn’t load the doc details.” and if I reduce it to the very basic https://docs.superhuman.com/embed/PWIOR0vq0U the error message I get is “Oops. There was an error loading pages.”
any ideas how to fix this, workarounds or even better ways to allow people to add data into tables they are not allowed to access?
thanks a lot,
jann
I had the same issue but I was using the old coda.io URL for the embedded form.
Just to be sure are you using the old URL that already existed or the new URL you showed in your post. Changing the coda .io parts in my embedded forms to docs.superhuman. com fixed it for me.
Thanks for ur answer! Unfortunately also with superhuman url it doesn’t work, the only ones that continue working are the once already set up a year ago…
So how did you set it up exactly? Because if I want to add an embed page with the URL to a superhuman form it automatically switches to the “new sync page” interface which then fails…
