It has been mentioned before, but a simple form view allowing data entry and editing seems a natural fit for Coda.
Useful, and thanks for drawing attention to this - but I was thinking something more adaptable.
I thought I had a solution to this problem, but it seems the Hide hidden columns option isn’t working for me:
here’s an example doc
If you want something more adaptable, like you only want to show the attributes that are interesting to you, one thing that you could do is make an Input Data view of the table you want and then select Hide hidden columns option
I blurred the example above because it doesn’t work. @mallika maybe you can take a look at this. It seems the View table isn’t working with Hide hidden columns
