# Formular to display text from position #
**URL:** <https://connect.superhuman.com/t/formular-to-display-text-from-position/25208>\
**Created:** [August 23, 2021, 6:42pm UTC](https://connect.superhuman.com/t/formular-to-display-text-from-position/25208 "2021-08-23T18:42:36Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![juergenheise](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/juergenheise/32/20217_2.png) [@juergenheise](https://connect.superhuman.com/u/juergenheise)\
**Post date:** [August 23, 2021, 6:42pm UTC](https://connect.superhuman.com/t/formular-to-display-text-from-position/25208/1 "2021-08-23T18:42:36Z")
</div>
I have the following use case: “#example” or “@example”:
Is there a formular that displays the text starting from the second character?
In both cases the result would be “example”.
**Author:** ![Scott\_Collier-Weir](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/scott_collier-weir/32/29677_2.png) [@Scott\_Collier-Weir](https://connect.superhuman.com/u/Scott_Collier-Weir)\
**Post date:** [August 23, 2021, 8:51pm UTC](https://connect.superhuman.com/t/formular-to-display-text-from-position/25208/2 "2021-08-23T20:51:34Z")
</div>
Hey there!
Try out this
 ![image](https://global.discourse-cdn.com/coda1/original/3X/3/3/338edb081ddec0a51aeccf75c747b78ee52246ed.png)
Let me know if you need any more help!
**Post date:** [August 24, 2021, 6:21am UTC](https://connect.superhuman.com/t/formular-to-display-text-from-position/25208/3 "2021-08-24T06:21:02Z")
</div>
Thank you. Works fine.
