# 🏗 Game Creator for LIP2-Engine
**URL:** <https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792>\
**Category:** Doc Show and Tell\
**Created:** [August 6, 2018, 10:14am UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792 "2018-08-06T10:14:02Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![Daniel\_Stieber](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/daniel_stieber/32/17045_2.png) [@Daniel\_Stieber](https://connect.superhuman.com/u/Daniel_Stieber)\
**Post date:** [August 6, 2018, 10:14am UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/1 "2018-08-06T10:14:02Z")
</div>
**Create your own adventure game based on the Lost in Paradise 2-Engine within minutes.**
Lost in Paradise 2: Out of the dark was completely created with the Game Creator. [Check it out.](https://connect.superhuman.com/t/game-lip2-out-of-the-dark/1791)
**Create your own characters** 🧒🏽👨🏽‍⚕️🧝🏽 🐅
You decide how the players will look like in your own game.
**Place collectible and consumable items** 🎣🎱🎫🥕
Get creative and fill the world with items that fit to your story
**Build an army of enemies** 🧟🧛🏽🐗
Create enemies and define, how strong they are.
**Create interactions** 📻📟🚪
Set up objects for interaction and define, which items players needs to interact.
**Design the environment** 🌻🕳🔮🌊
Complete your story with a thriving world including traps and more.
**Screenshots**
> **Set up the basics**
> ![18](https://global.discourse-cdn.com/coda1/original/2X/f/f6d9df0969d0c49dd8f13f15f6e4db98cc0d8def.png)
> **Items**
> ![31](https://global.discourse-cdn.com/coda1/original/2X/a/a2142624ba97467ce5a842664abd879643f398e1.png)
> **Interactive objects**
> ![42](https://global.discourse-cdn.com/coda1/original/2X/8/877e0165138dac1f51dde885d87f229546c49865.png)
> **Enemies**
> ![22](https://global.discourse-cdn.com/coda1/original/2X/1/11cc6c42d4a8e1861923a020c986c61b557ba9c9.png)
Read the handbook-section for more details on how to use the Game Creator.
**To use, open the shared document, make a local copy (click the arrow at the document name) and start:**
**[-\> Copy your version of the Game Creator](https://drive.google.com/file/d/1LyCQMJETbYZjx-Kem2XbjW7sags7zMKH/view?usp=sharing)**
If you really make a game with this, don’t forget to share it with the community 🙂
**Contribution**
You have some great ideas for the next version? Just write me a PN and join the fun 🙂
**Author:** ![mallika](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/mallika/32/12981_2.png) [@mallika](https://connect.superhuman.com/u/mallika)\
**Post date:** [August 6, 2018, 4:47pm UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/2 "2018-08-06T16:47:51Z")
</div>
@Daniel_Stieber - what a wonderful thing to see on a Monday morning. Clearing our a block of time later in the day so I can dig in.
**Author:** ![nathan](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/nathan/32/5616_2.png) [@nathan](https://connect.superhuman.com/u/nathan)\
**Post date:** [August 6, 2018, 5:01pm UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/3 "2018-08-06T17:01:00Z")
</div>
Amazed by this. Love how you extracted the game engine from the details for a specific game, as well as the simplicity with which you can define game-specific logic.
Really fun too to peek in the engine & currentgame sections to see how it all works.
**Author:** ![Akash\_Agarwal](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/akash_agarwal/32/37437_2.png) [@Akash\_Agarwal](https://connect.superhuman.com/u/Akash_Agarwal)\
**Post date:** [November 9, 2023, 4:54am UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/4 "2023-11-09T04:54:42Z")
</div>
@Daniel_Stieber does this still work? The link takes me to GDrive.
**Post date:** [November 9, 2023, 7:37am UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/5 "2023-11-09T07:37:29Z")
</div>
Hey @Akash_Agarwal , the link is from a time when sharing docs was done via GDrive. Unfortunately I think the engine itself is no longer working due to updates in Coda that changed some behaviour, but I will have a look and check later today.
**Post date:** [November 9, 2023, 9:21am UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/6 "2023-11-09T09:21:04Z")
</div>
I made a view changes and published it properly. That should work now with the current version of Coda.
> **[LIP2 Game Creator REMAKE (community)](https://coda.io/@danielstieber/gamecreator)**
**Post date:** [November 11, 2023, 10:19pm UTC](https://connect.superhuman.com/t/game-creator-for-lip2-engine/1792/7 "2023-11-11T22:19:40Z")
</div>
Thanks heaps @Daniel_Stieber!
