# Generate "work load" view per team member?
**URL:** <https://connect.superhuman.com/t/generate-work-load-view-per-team-member/13399>\
**Created:** [January 22, 2020, 11:28am UTC](https://connect.superhuman.com/t/generate-work-load-view-per-team-member/13399 "2020-01-22T11:28:57Z")\
**Posts on this page:** 2\
**Page:** 2
<div class="post-metadata">
**Author:** ![Johg\_Ananda](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/johg_ananda/32/13930_2.png) [@Johg\_Ananda](https://connect.superhuman.com/u/Johg_Ananda)\
**Post date:** [January 28, 2020, 7:00pm UTC](https://connect.superhuman.com/t/generate-work-load-view-per-team-member/13399/21 "2020-01-28T19:00:23Z")
</div>
Yes thats why I suggested a contorl, otherwise you need to contemplate all conditions.
If we get a good solution to the ‘[Outer CurrentValue](https://connect.superhuman.com/t/outer-currentvalue-access/8048)’ situation this would become even easier, but for now I think the select/table is the way to go.
**Author:** ![Stefan\_Singer](https://yyz1.discourse-cdn.com/coda1/user_avatar/connect.superhuman.com/stefan_singer/32/12491_2.png) [@Stefan\_Singer](https://connect.superhuman.com/u/Stefan_Singer)\
**Post date:** [January 28, 2020, 7:01pm UTC](https://connect.superhuman.com/t/generate-work-load-view-per-team-member/13399/22 "2020-01-28T19:01:39Z")
</div>
Ah, I didn’t first fully understand your suggestion. Will definitely try that!
[Previous page](https://connect.superhuman.com/t/generate-work-load-view-per-team-member/13399.md?page=1)
