How do I connect Grok Bot to Coda Docs MCP? Thanks!
Just ask GrokBot to connect to the Superhuman.com MCP server.
It will ask you for the necessary details and do the rest.
Max
Unfortunately, that does not work. The bot wants a personal access token which I am hesitant to put in the thread. Coda Docs, is there a dedicated MCP link for Grok Bot?
Grok Bot should always give you control over the browser to do logins and API credential approvals.
Once this is done, the rest of the session will have the access you granted.
So when you ask the Grok Bot to connect to your Superhuman workspace, it should ask you to log in manually, not save the password.
If you are connecting to the MCP or API endpoints, it should ask you to provide the credentials manually, not save them.
This does mean that each session needs these manual steps.
As the product evolves, we expect to see secure mechanisms for providing these credentials that are not shared as part of the session.
But for now (its only week 2) we must use the manual approach.
So, just like OpenClaw, we must NOT give unrestricted access privileges to GrokBot until this is resolved.
You can always generate a more restricted token from the Superhuman side and use that for automated connections.
I also hope that someone will build a Superhuman Go Connector pack for the SpaceXAI system that will control access from the Superhuman side.
Its early days - so we experiment with caution.
EDIT:
actually, the reason i may not be answering your specific question is because i use GrokBot as an AI driven BROWSER and so i am logging it into my Superhuman workspace as a USER and not via the API or MCP.
very much NOT READY for production. i treat the lobster as a version of myself. it sees what i can see. it does what i can do. hence the need to experiment with caution.
sorry if this does not help
I used a SAAS product called Composio to connect. It works well.
