I have one column (Column A) that has a list of tags (i.e. “Turtles”, “P1”, “Bug”) and I want to set up another column (Column B) that has the following logic: “IF Column A contains “Turtles” then Column B displays “Turtles”.”
How might I do that? Would SO appreciate any help!!
So, basically my use case is that I’ve got a column of Linear labels and I want to separate out the customer columns so I can easily group by customer. So if one customer is “Turtles” and another customer is “Cats” and another is “Giraffes” how would I write that such that if it’s not turtles, it doesn’t say “not turtles” but instead it says the customer that is is?
