Is there any way to make a hex value picker in coda.
E.g somthing that looks like this:
(without the fonts?)
Any tips or hacks on this?
I don’t think so. As far as I know, you can’t even set the colour of a cell to a hex value, let alone connect that to the value of a cell.
I built this somewhat silly example, but I don’t think it gets you close enough to what you want:
You could expand it out to add HSL sliders as well, and google for the algorithm to convert that to the RGB that Hex is under the hood.
I had the feeling. I could try to connect it to integromat and get a hex color picker api.
Not sure the context of your doc, but could you have everyone using it install a color picker Chrome extension or something like that?
@BODHI_SCHNEIDER @Nick_HE I built an HSL slider a WHILE ago when I was trying to learn Coda and understand the RGB to HSL conversion. I’d go about it very differently if I built it now. I hope it’s at least amusing if not super helpful.
Totally forgot about the shape tools! Nice
