I’m working on a project in Coda.io and I need to add a block or section where users can draw or sketch directly inside the document.
Could you please guide me on how to create this drawing block or what the best approach is?
Thank you very much in advance for your help!
Hi Carlos, you can create an embed block with something like AutoDraw, but the drawings won’t be stored anywhere in Coda. Does that help you?
Hi Pablo
, I need images to be able to be saved even if they are in base64
Unfortunately there is not a straightforward solution for your use case, but you can add your vote here
