Hello!
I have a pretty simple select (at least I think I do) and has “Manager” selected as well as other values. Please see below in the screenshot. I am just wondering why I get TRUE when only “Manager” is selected vs getting FALSE when “Manager” and something else is selected.
Link is here if you want to play around with it!
I added a new column for you called Contains.
You need to check “Does Role contain Manager?”
Role.Contains(Manager)
Got it, I was thinking I could do it by text since toText, to me, would work just the same.
Can I get the idea behind this? I can only compare row values to other row values?
I got it, it works with this formula as well!
thisRow.Role.Lower().ContainsText(Lower(“manager”))
Thank you for the help!
So your solution works, but two things…
You’re adding an unnecessary column and formula
Using text match is less accurate. If you add a role like “senior manager,” then that will match as well.
In the column I added, it will ONLY match “manager.” That is the recommended solution when you are comparing to a select list column.
system
Closed
July 22, 2024, 9:39pm
5
