How can I trigger an action automatically after X minutes without using an external service?
Hi everyone!
I’m building an Andon escalation system in Docs for a manufacturing plant, and I’m trying to solve one specific challenge entirely within Coda if possible.
Here’s the basic workflow:
  1. An Andon is activated.
  2. Level 1 (N1) is notified immediately.
  3. If nobody responds after 10 minutes, automatically escalate to N2.
  4. If nobody responds after 20 minutes, automatically escalate to N3.
  5. As soon as someone responds, the escalation stops.
The escalation times are stored in a configuration table, so they can be different depending on the support function.
For example:
Maintenance
N1 = 0 min
N2 = 10 min
N3 = 20 min
Quality
N1 = 0 min
N2 = 5 min
N3 = 15 min
I already have the rest of the workflow working.
When the Andon is activated, a writable column changes and a Row Changed automation sends the N1 Microsoft Teams notification immediately.
The challenge is:
How can I generate a REAL row change automatically when X minutes have passed?
I can calculate things like:
Now() >= [Next Escalation]
and I can display a live countdown/timer.
However, as I understand it, a formula changing from FALSE to TRUE does not trigger a Row Changed automation because the underlying column is calculated rather than writable.
Ideally, I would like something like:
Andon activated
→ Start timer
→ 10 minutes pass
→ Automatically trigger an action/button
→ Change Escalation Level from N1 to N2
→ Row Changed automation runs
→ Send Teams notification
→ Start waiting for N3
I know this could probably be solved with Power Automate, Make, Zapier, or the Coda API, but before adding another service I want to make sure there isn’t a clever native Coda solution I’m missing.
Has anyone built something similar?
Is there any native pattern using automations, buttons, helper tables, formulas, webhooks, Packs, or another Coda feature that can reliably execute an action after X minutes?
The important requirements are:
• Resolution needs to be in minutes, not hours.
• It needs to work even if nobody has the doc open.
• Escalation times need to remain configurable in a table.
• It should stop automatically once someone responds.
• Ideally, I want to keep the whole solution inside Coda/Superhuman Docs.
Also, with the new Agents in Superhuman Docs beta, I’m curious whether an Agent could potentially act as the “escalation monitor” and periodically check for overdue Andons and take action.
Any ideas or patterns would be greatly appreciated. Thanks!
hello @Victor_Ballesteros1 ,
Welcome to the community and thanks for the interesting question.
There is no direct native Coda solution available as far as I can see since row change requires a human intervention and not a formula driving change and coda has no intervals smaller than one hour.
there are a few options:
use a webhook and link to a free cron job service like Free cronjobs - from minutely to once a year. - cron-job.org, no need for a glue factory like Zapier or Make
create your own pack (with AI that is not so difficult these days).
wait for the Agent logic, that may solve the issue over time for you. In Claude there is something simular (Routines).
I hope you got some inspiration to figure it out on your own.
Cheers,
Christiaan
the first action formula can pause for 10 minutes using the _Delay(Second_Action, 1000*60*10) formula.
and the same for the Second_Action formula etc.
The Second_Action button would need to check to see if the ticket was updated or not.
The _Delay() function is a hidden function, but has behaved perfectly reliably in all our workflows for many years.
:crab:Max
merci @Max_OBrien for pointing this out. Since the Delay function seems to be stable, it is about time to formalize it. Many makers would love this.
Every time I think I have learnt this platform inside out, I read something like this. Nice one @Max_OBrien
If you have a rule against using hidden or unsupported formulas (which we do on important production documents)
The path we will usually use is the scheduler pack by @Leandro_Zubrezki
Free pack! Works like a charm
Scott weir, Simpladocs
